I have a model in which two plane surfaces (formed by shells) will contact both in the surface and the edges. However, when I try to model a TYPE7 contact, I need the Gap to be dependent of the thickness (as in Igap=2) in that direction, but this leads to a Gap that would not be realistic in the edges, where the 'last' node is geometrically at the edge. I have tried TYPE11 Interface in that area to avoid this but the Igap is still at work and the parts contact 'before' they should.
To sum up, I would need the contact area to be the blue marked area in the picture.
