Which network accesses and ports are necessary to use the version check with ConnectMe?
I think this app uses common ports like 80 or/and 443. But I'm not sure about this.
Nothing about protocol and port in the doc.
ConnectMe uses port 443 (SSL) to pull catalog data. Are you asking about the endpoint?
