I am trying to follow the OS-T-2098 topology optimization tutorial in 2024.1 and I am having issues. I've noticed none of the tutorials are updated for the GUI change but I've been able to find the options/parameters well enough to do all of them except this one.
The issue I am having is part of the tutorial tells me to change the lower arm from a PRBODY to a PFBODY. In 2022 and earlier versions, it gives you some parameters you can change (CMS method, NMODES, etc). But in 2024, the only way I can change from a PRBODY to a PFBODY is in the Groups collector and I don't see any of those parameters that I can set. When I try to run the optimization, I get a failure.
If I run through the tutorial using 2022, everything works fine.
Thanks!
