Hi
I am doing FBO and Windmilling Frequency Response Analysis for two rotors engine system.
Is to possible to run frequency response analysis with two rotors, with two different unbalances and one is rotating at constant speed and other one sweeping from 0 to 300Hz. If yes, please send me the master deck how to do that. Thank you very much.
With Regards,
Chandra
Hi Chandra,
The solver gives error if one is rotating at constant speed. The workaround could be to define a small range of speeds like the below:
Thanks.
Xiaolei
