Hello
I used delay function in c block
But there is no change in the answer output
And by the way, the code composer software gets an error from this function
What should I do to fix this error?
Or what should I do to delay the c block.
Dear User,
The "C block" and the "Simplified C block" in PSIM support a specified list of functions. You can find this list by navigating to the "Help" option of the "C block":
The delay function is not a part of that list and won't work the way you want it in the simulation. What you can do is add a "Unit Delay" block at the output of the "C block" if a certain condition is met. This can add the delay to the output signal.
