Hi all,
Can anyone explain for me what is F in this equation? I'm modeling sand material use MAT LAW 21.
Hi Nancy,
This F parameter is set in order to define the yield point. The following is true for your material based on F value:
This parameter can also be used for Von-Mises yield criteria, where the pressure-dependent terms are equal to 0 and A0 = yield point. This can probably help you to better understand the use of this value.
Polyvios
