Hello
In one program, I set the encoder resolution to 4032
But the encoder output is reset before reaching 4032 and it is not reset to zero
And every time it counts to a certain amount.
What could be the reason?
Please check your sampling point when the encoder output is read.
Thank you for your answer
But where can I check this sampling point?
