Hi all,
I'm doing a task with Exoskeleton Design Space, with Design variables: Topology (Figure 1). HyperMesh will inllustrate the newly generated exoskeleton (1D elements) (Figure 2) - represented by CBEAM elements with beamsection as shown in figure 3. After I run the optimization, I can define where structure need to reinforce (Figure 4) (to not eceexed the optimization constraint). The question is, can I run a size optimization (after topology optimization) for these beams in figure 4?
Thanks for your reading
