Hi everyone,
I'm using Inspire Motion to simulate the motion of a robot arm. Part 1 (yellow) connects to the ground part, and controlled by the motor 1. Part 2 (red) connects to the part 1 and controlled by the motor 2. Each motor has its own function. When I run the analysis, Inspire give me a warning (shown below). I've tried to activative Restrain Centerline (motor 2) but the result is unrealistic. I also increase the Deformation Allowed.
What should i do in this case?
Thanks all for spending your valuable time!
