Here is a screenshot of what is shown whenever I try to open the software.
You are opening the job launcher of MotionSolve, assuming that you already have a .xml file from MS to run. Then you just select your pre-existing model file, and run it without opening the model in the interface (MotionView).
So if you're looking for the GUI, you should search for MotionView (it comes into the HWDesktop installation package).
You are opening the job launcher of MotionSolve, assuming that you already have a .xml file from MS to run. Then you just select your pre-existing model file, and run it without opening the model in the interface (MotionView). So if you're looking for the GUI, you should search for MotionView (it comes into the HWDesktop installation package).
I did not get this answer well. Would you be more clear please?
However, I want to include the complex motion of a swing jaw and I can do it by coupling EDEM and MotionSolve.
