Is it possible to use the ESC key for the Unselect All command as it was done in S-Frame 2022?
Hello Roman, thank you for your post.
So far we have noticed that the feature is not available but our team is looking into it and we will try to add it back in a future release.
Thank you for bringing this to our attention.
Best,
Tayen Aguilar
Altair Support
Odd to have removed this command/feature? Been in the software forever.
2023.1 was released but the issue is still there...
Hello Roman,
Thanks for following-up. Unfortunately the timing of the 2023.1 release did not allow us to implement this fix before it was made available. With that said, the fix is currently being tested, and we can let you know when it becomes available. We are sorry for the inconvenience, and appreciate your patience.
Regards,Matthew Sauer
Hello Roman, Thanks for following-up. Unfortunately the timing of the 2023.1 release did not allow us to implement this fix before it was made available. With that said, the fix is currently being tested, and we can let you know when it becomes available. We are sorry for the inconvenience, and appreciate your patience. Regards,Matthew Sauer Altair Support
Hello Roman, I am writing you to inform you that Version 2024 of S-FRAME was released, and includes a fix for this ESC button issue. You can download the latest version of the software from our Altair Marketplace. Please let us know if you have any issues doing so.
Hello Trevor, I am writing you to inform you that Version 2024 of S-FRAME was released, and includes a fix for this ESC button issue. You can download the latest version of the software from our Altair Marketplace. Please let us know if you have any issues doing so.
Hello Roman, I am writing you to inform you that Version 2024 of S-FRAME was released, and includes a fix for this ESC button issue. You can download the latest version of the software from our Altair Marketplace. Please let us know if you have any issues doing so. Regards,Matthew Sauer
Hello Matthew,
Thanks for the update. Unfortunately, I can't enjoy the ESC button due to the license error that happened in version 2024 (case CS0617405)
Hello, Roman,
We received your message and shared a suggestion for the v2024 issue through the case number you shared, please review them.
Alejandro Lopez
