Encoder conversion to hall effect sensor
User: "reza hakimi_20486"
Altair Community Member
Updated by reza hakimi_20486
Hello
I use an encoder in a practical project to measure speed
But I also need Hall effect sensor signals
What do you suggest for making hall effect sensor signals using encoder
In the program, I temporarily used the hall effect sensor on the bldc motor in order to perform the simulation
1 - 1 of 11
    OP
    Hello
    I want to change my question as below, maybe I will get the answer faster this way
    I have a square signal whose frequency changes during the simulation time
    Now I want to make a square wave from it, which I reduced the frequency of at a constant rate, and I want to start making this signal with the first rising edge of the main wave.
    What tool can I use that can generate code?
    The upper signal is the main signal
    The lower signal is also the signal that I want to make
