Hi! can anyone please guide me how to re arrange the trace text, I want mode 1 to appear 1st and then 2nd-5th
Regards
Hi @RF Engineer
You can raise or lower a trace on the result palette (the panel to the right of your graph window), using the right-click context menu or selecting the trace and pressing Ctrl and + (or Ctrl and - to lower):
This will change the order in the legend as shown.
Hi @RF Engineer You can raise or lower a trace on the result palette (the panel to the right of your graph window), using the right-click context menu or selecting the trace and pressing Ctrl and + (or Ctrl and - to lower): <?xml version="1.0" encoding="UTF-8"?> <?xml version="1.0" encoding="UTF-8"?> This will change the order in the legend as shown.
Thank you so much
