HelloFor the pi controller shown in the figure, I am going to make the following entry so that it has the ability to create code, I did this with c block, but there was a problem in creating the code. What solution do you suggest for this problem?
You can use the lookup table, for the time input. If you integrate "1" you will get time in seconds. example attached.
