How to extract (.pch) reduced matrices when using CMSMETH GM (General Method)?
User: "Pedro_Millan"
Altair Community Member
Updated by Pedro_Millan
Dear all,
I'm running a model reduction and I would like to extract the reduced matrices as a .pch file (ASCII format) when using CMSMETH GM (General Method).
When I use the CMSMETH CBN (Craig Bampton Nodal), the matrices are correctly output (I am using PARAM, EXTOUT,DMIGPCH and PARAM,MASSDMIG, to print the corresponding stiff and mass matrices, respectively). However, when I use CMSMETH GM (General Method) instead of  CMSMETH CBN (Craig Bampton Nodal), the .pch file is not created. Does anyone know how to overcome this issue?
Thank you all.
1 - 1 of 11
    User: "Xiaolei"
    Accepted Answer
    Updated by Xiaolei
    Hi Pedro,
    You are right that punch format is not supported for GM method.
    This limitation is due to an accuracy consideration.
    Xiaolei
