After exporting a motor geometry from flux motor how can i modify it in flux 2d, when i try to force delete a point i get an error message saying it is protected
Hi Haroun Amir,
The points of the infinite box are protected.
You need to delete the infinite box, one way is by using the Menu: Geometry>Infinite box>Delete.
Best regards,
Alexandru
Hello Haroun,
First, make sure you delete the mesh.
Then, try to force delete the point instead of normal delete. Sometimes, when used in other instances, points are protected from deletion.
Or Check the usage of particular point. Delete those usages and then delete the point.
Thank you,
Lavanya
