I'm trying to run the optistruct analysis in this model. The goal is:to set 3 contacts with interference, to put a constraint on the upper surface,to put pressure on 2 areas.
I'm attaching the file.
Can you help me?Thank you
Hi everyone,
now it works.I've just considered a larger area of contact.
I'm attaching the new file if it can help someone
