I would like to run linear buckling analysis. I would like run an analysis that uses a TEMP load as the "force" and evaluate buckling. The buckling is caused by SPC constraints or by cooler zones within the part. I have added the TEMP load collector using the TEMP_LOAD, but it does not seem use the buckling analysis in the result. Anyone please let me know if this is possible. I have added a simple beam model attachment of what I was using.
