Hi All,
Can I export my simulation as a animation file (e.g. as a .fbx file) for import in an animation software (e.g. belnder)?
Could not find anything, maybe there is a workaround?
Thanks and best regards
Leandro
Hi Leandro,
You can directly render EDEM results in InspireStudio which you might have access to under your license:
How to Render EDEM Videos and images
You can export the geometry and particles as .stl meshes:
You could also get the data out of EDEM using EDEMpy and format into something that your rendering program of choice would like:
EDEMpy Introduction guide and tutorial
Best regards,
Stefan
Thanks!
