Hello everybody,
today I'm studying a snap-fit analysis. The model is linked at the end of the post.
I'm trying to change some setting parameters and observe the behavior of the system. In particular, I focus on SCALE, S1 in CNTSTB load collector.
I don't understand how to set SCALE and S1 for obtain correct results, because in some online examples (like OS-E: 0155) SCALE=0.01 and S1 = 0, but in others (like this: snap-fit.pdf (hubspot.net)) SCALE=1 and S1=0.0001.
The problem is that, varying SCALE, I get different results in the force insertion (SPCF along Z at the center of rbe2 at the snap's base). Furthermore, varying SCALE and S1, the load step can converge or not depending on their numerical values.
I imagine that SCALE influences the contact stiffnes, so the force insertion. S1, on the other side, is only a parameter for stabilize contact at the end of simulation.
Can anyone explain me how to choose correct numerical values for obtain consistent results?
Thanks
Francesco
