I want to do CFD run for a ceiling fan having 3 blades.
My system has components like wall, MRF and Interface. MRF is the cylindrical solid from which the Fan is subtracted. Walls form a room in which the air flow has to be monitored. For volume meshing I have used boundary layers at the interface of 2 layers and 5 layers on the MRF; whereas no BL is given to walls. Mesh is done using Tetras. My turbulence model is Spalart Allmaras.
Is my way correct? Please suggest better way.
