I have ERROR IN INPUT FORMAT. Does anybody tell me the solution?
Naoto Asakura
Naoto Asakura New Altair Community Member
edited October 2021 in Community Q&A
I made a bended coil as attached below and ran Radioss.
I got this message.
any solutions??
ERROR ID : 266
** ERROR IN INPUT FORMAT
DESCRIPTION :
INPUT VERSION 2021 IS NOT SUPPORTED
ERROR ID : 266
DESCRIPTION :
.. BLOCK FREE FORMAT
WARNING ID : 1114
** WARNING WHILE READING
DESCRIPTION :
THERE IS NO DEFINED PART IN INPUT FILE.
.. STARTER RUNNING ON 1 THREAD
.. CONTROL VARIABLES
.. UNITS SYSTEM
.. FUNCTIONS & TABLES
.. MATERIALS
.. NODES
.. PROPERTIES
ERROR ID : 315
** ERROR IN BEAM PROPERTY
ERROR ID : 316
ERROR ID : 317
.. 3D BEAM ELEMENTS
.. SUBSETS
.. ELEMENT GROUPS
.. PART GROUPS
.. NODE GROUP
.. BOUNDARY CONDITIONS
.. CONCENTRATED LOADS
.. DOMAIN DECOMPOSITION
.. ELEMENT GROUPS
.. RIGID BODIES
.. ELEMENT BUFFER INITIALIZATION
WARNING ID : 275
** WARNING IN RIGID BODY DEFINITION (INERTIA)
ERROR ID : 274
** ERROR IN RIGID BODY DEFINITION (INERTIA)
WARNING ID : 312
** INCOMPATIBLE KINEMATIC CONDITIONS IN MODEL
DESCRIPTION :
3 INCOMPATIBLE KINEMATIC CONDITIONS IN MODEL
.. GEOMETRY PLOT FILE
.. ERROR ==> NO RESTART FILE
ERROR TERMINATION
8 ERROR(S)
3 WARNING(S)
PLEASE CHECK LISTING FILE FOR FURTHER DETAILS
==== End of solver screen output ====
==== Solver FAILED ====
==== RADIOSS Job completed ====
  • HarishT
    HarishT
    edited October 2021
    Hi Naoto Asakura,
    In your model you missed to select the part card in the card image for the spring element.
    Also for the spring element you need to assign the property which you created, and for rigid element you need create the separate component which doesn't require any part card.
    Also please run in the latest version.
    Regards
    Harish
Welcome!
Welcome!
