error id 760 for radioss model
I am new user of hyper mesh. I encounter a error when I ran radioss.
The error id is 760
It says I add solid property to shell elements.
But in my model, there is no shell elements.
Is it due to my mesh method ?
I mesh the surface first and then use solid map mesh.
The orginal file is attached as below.
Please review it.
Thanks.
Hi @yugang,
yes, the error is due to your mesh method (solid map using shell elements).
Shell elements used to construct 3D mesh with solid map should be deleted before simulation:
1. Isolate the components with solid mesh
2. mask 3D elements
3. delete shell elements used for construction
It is a good practice to create constructional shell mesh in a different component.
