how can simulate rbe3 in Simsolid?
Hi Giuseppe,
There are no rbe3s in SimSolid. Can you describe your use-case as to how you would like to use rbe3s?
I have to transfer on red dots the load
You can use remote load for this, it does not rigidize the area of load application and should work similar to rbe3.
thks, i'll try
