Dear Sir or Madam
During my simulations I found out something that seems quite confusing for me.
This a simple model of magnet and sensors. Magnet remanence is oriented only around Z axis. After calculations i exported all the data to excel files and everything seems to be fine.
Then I rotated the whole design by 90 degress. I expect results will be the same because magnet and sensors are in the same place in regard to each other. Unfortunately, output results are also rotated. Am I missing something important, or maybe results are exported based on global XYZ system?
Thank You in advance
Best Regards
