What parameters can be changed after particle generation?
User: "Shinichiro_Oshiro"
Altair Community Member
Updated by Shinichiro_Oshiro
Hi.
I would like to analyze the impact of particle and geometry parameters on the results. After performing calculations for a certain period, I want to output the results with SimulationDeck and continue the analysis by changing the parameters.
However, I am aware that there are parameters, such as Solid density, that do not reflect changes in values.
Please let me know which parameters are reflected in changes and which parameters are not reflected when you modify them after generating particles.
Thanks
1 - 1 of 11
    User: "Stefan Pantaleev_21979"
    Accepted Answer
    Updated by Stefan Pantaleev_21979
    Hi Shinichiro,
    All particle material properties except the solid density and all particle interaction and physics properties can be modified after particle generation.
    If you need to change the particle density after generation you can do so by modifying the particle template mass in the .h5 files but this is not supported and may be unsafe.
    Best regards,
    Stefan
