Disable OpenGL error message when running EDEM+HyperStudy on a Virtual Machine
Hi EDEM Experts,
We want to run Hyperstudy+EDEM on a remote virtual machine but everytime we open EDEM or start jobs in Hyperstudy the error message of OpenGL will pop up (see picture below). There is no GPU available on the virtual machine, how can we disable this error message pop up?
Hao
Hi Hao
In the nominal run of yours in HyperStudy in the 'Setup' study (or whichever study you are using in the 'Definition' of your 'DOE' study), please make sure that OpenCL is not selected in the EDEM Simulator for that particular simulation. Make sure that you have CPU selected in the Simulator.
Hope this helps.
Thanks,
Jerrin Job0 -
Jerrin Job Sibychan said:
Hi Hao
Hope this helps.
Thanks,
Jerrin JobHi Jerrin Job,
Thanks for the suggestion. The original Setup was set with CPU as the solver engine in the simulator. The error actually comes before it enters into the solving routine. It detects no graphical card on the virtual machine and immediatly showing the error and dispaly in legacy mode when the simulation is opened. I want to just disable this error.
Best regards,
Hao
0 -
Hao Shi said:
Hi Jerrin Job,
Best regards,
Hao
Hi Hao
Are you able to run an EDEM simulation without HyperStudy in the VM?
0 -
Hi Hao
Yes, I can run the simulation without HyperStudy in the VM. The error pops up whenever the EDEM programme is called/openned.
0 -
Renan Calmon_20325 said:
Hi Renan,
Thanks for the heads up. We have tried this method but it also doesn't work. We cannot turn off the setting of "Render all using legacy display", it is always selected, see picture below. The virtual machine has no GPU or OpenGL compatability. Maybe you know another workaround?
Best regards,
Hao
