Shear center or neutral axis
Alex Nguyen
Alex Nguyen Altair Community Member
Hi everyone, I have some matters with 1D element.
In beam structure, connecting locations by welding include shape steels as channel and angle steel (nonsymmetrical section) . Absolutely, we shall model these steels into lines. Shall we create lines on shear center or neutral axis ? What case is suitable for behavior in real-life?
Thank you everyone
Best Regards.
  • tinh
    tinh Altair Community Member
    edited March 2019
    Depend on your real structure: forces are transfered via welds, sum of these forces called total force and I think beam's node should be at position of the total force.
  • Alex Nguyen
    edited March 2019
    Thank you Mr. Tinh
    Assuming I create line at shear center and connect lines together by RBE2.  That's alright ?
    Best regards
  • tinh
    edited March 2019
    Please refer to CBEAM card info in Optistruct Reference Help, you could need to set offset values.
  • Alex Nguyen
    edited March 2019
    Thank you so much Mr.Tinh :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
