Rendering Tyre Tread In Evolve
BrettL
BrettL Altair Community Member
Hey guys,
Can anyone give me some tips on the best way to render a tread on a tyre in Evolve? I've tried using a material with the tread as a bump map but it doesn't come out deep enough.
I've also tried a displacement map but it gets very strange results even though the texture appears to be positioned correctly.
I've tried a pixel map too which works ok but the tread is very coarse/jagged and it doesn't seem to have a high enough resolution.
I've attached a sample file and tread texture. Any tips or example files would be greatly appreciated!
Cheers, Brett.
  • ArjunA_22390
    ArjunA_22390
    edited February 2016
    BrettL,
    I think the smoothness value for your pixel map was set to 10 and this negates any sampling resolution set. Even though you had 500x47 samples, a smoothness value of 10 will revert it.
    Please change the smoothness to 0 and you should achieve the desired results. Attached is what I achieved using this method.
