I was just wondering if there's any way to do panoramic / stereo rendering for VR applications in Evolve 2016?
I found this help topic for creating Quicktime panoramic VR movies in 2014 but can't seem to find any similar options in 2016:
http://www.solidthinking.com/tutorials/2014-tutorials/mac/help/quicktime_vr_movies.htm
Any help would be much appreciated...
Hi BrettL,
I am afraid this feature is not available in the newer versions of Evolve. You can only render individual frames in 360 panorama. I will talk to the development team and see if this is something pre existing and can be exposed in the settings.
Thanks Arjun, would be good to see it as a feature in the latest version given it was there previously.
I've found a bit of a workaround by uploading models to Sketchfab, which has a VR viewing mode, but this has raised another issue. If I apply materials/textures to a model in Evolve, is there any format that I can export in that will maintain those materials? If I export .3ds there's no materials at all. If I export .obj, it creates a .mtl file but each material in the file has the same name, same properties, and if I import that .obj into any program (including Evolve), there's no materials.
Any tricks to get materials into other formats??
Looking at it right now. I will have to investigate a bit. If there is a bug, I will update here and when you can expect a fix.
