Deformation scale factor
Yash Mehta_21095
Yash Mehta_21095 Altair Community Member
edited May 2024 in Community Q&A
When I am running Deformation simulation, the scale factor is set to default, which is so exaggerated. But I want to see the actual deformation which will take place at a scale of 1.0
But when I am changing scale factor to 1.0 it is not showing actual deformation what it should be in reality as the displacement given was 30mm.
So, I wanted to do same as ANSYS workbench, where we can change the scale units.
  • Girish Mudigonda_21018
    edited May 2024
    Once you have input the deformation scale factor, you need to also select deformed shape to see it, see option below.
