In a 112 dynamic analysis, with a multi-channel time-history force input, how to output the acceleration in a RP3 binary format? If RP3 format is not available, what are the options?
Hi Ivan,
Honestly I've never heard of RP3 format. Could you explain where does this format is accepted?
You could export the acceleration data for a node set in many different formats from OptiStruct.
PCH and OPTI are ascii/text formats
OP2 and H3D are binary readable by HV/HG
