My goadl is to create virtual bushing by importing .csv file in Simsolid
My fastener.csv file contains the following data :
| X,Y,Z,Diameter,Stiffness linear X,Stiffness linear Y,Stiffness linear Z,Stiffness angular X,Stiffness angular Y,Stiffness angular Z,Coordinate system id |
How can I proceed ? because it does not work.
How and when can I import in the model the coordinate system (with .csv) used in the bushing definition ?
Thank you !!
