Good morning,
I would like to ask you about a problem that I am having while performing a composite optimization.
After the Size Optimization is completed, I open the file whose name finishes in shuffling.XX.fem and there, I should find the plies whose thickness should be a multiple of the value of TMANUF that I specified, prior to running the optimization, in all the plies that were generated after the free size optimization. However, those plies do not appear...
I think that I performed succesfully the free size optimization since each ply of the original model was divided in four plies since I did not change the default parameters. I only changed the value of the TMANUF found on the plies (ex: 0.25mm), the upper bound of the size of all the design variables to double that value (ex: 0.5mm) and the control card OUTPUT from FSTOSZ to SZTOSH
Is there something I am missing? because I do not get the information of the plies after this optimization and therefore I cannot continue with the shuffle optimization.
Thank you in advance!
