Unable to save .hm file...coming further message...
'Unable to save model file. Check file permissions.'
even though deleting setting files and making rinstallations of software.
Please provide me solutions of same......
Can you try saving the file in admin login and also check if the folder you are saving the model in has Read/Write permissions.
Yup...i have all permissions as i m administrator of pc. Even though i m unable to sort this problem.
Please give me solution
Is that happening for same file?Please check with other file aswell.
If issue still persist please share same Hm file with us.
Make sure there are no special characters in the directory name and structure,
Go to security settings of that folder and ensure you have all permissions for the folder,
