uninstall hyperworks
I downloaded the student version of hyperworks but I had a license issue. So I uninstalled it by going to Control Panel -> programm -> uninstall programm and then I installed it again. However, when I look for hyperworks in the computer it does not find it, I can not even start the program. So I tried to uninstalled it but it did not work. Can you tell me how I can uninstall this version of my computer? thank you
are you specifying a known location for the installation? what do you find in this location/
you may have to manually delete altair files from the registry Start>run and type in regedit and then do a reinstall,
make sure you clear your temp folder and there is enough space in the location you are installing the software,
