I've installed HyperWorks 14 and Xquartz on Macbook Pro. The following window appears when opening Hypermesh.
Kindly suggest a solution to the problem.
Best regards,
Sreenath.
In order to provide advanced graphical capabilities and features in the HyperWorks products, there is a minimum requirement of OpenGL 3.1. Not meeting this hardware and driver requirement may cause problems with newer HyperWorks versions and features. Performance of HyperWorks may be degraded with compositing desktop effects enabled under Linux environments. Under Linux, HyperWorks 12.0 sets the environment variable XLIB_SKIP_ARGB_VISUALS=1 in the startup scripts, which may degrade GUI menu performance. To override this option set the variable XLIB_SKIP_ARGB_VISUALS=0 within the system’s or user’s environment.
VISIT: custom essay writing service
The MAC version of the student edition has been discontinued, If MAC is the only available machine, we suggest you install windows in parallel using boot camp, and use the windows version of the software. Apple support has all the details on this, https://www.apple.com/in/support/bootcamp/
Hello.
