I am having multiple issues in my laptop in installing software due to the Error code 2000-0151 which might have occurred in my device. What shall I do or what other alternative methods shall I try to get rid of such issues?
Hi dossgenny007
This error seems like a hard disk booting issues. Please try to fix it as recommended by your laptop manufacturer
or if you have a different laptop/PC then apply for a new license
2000-0151 error indicates your hard disk drive (HDD) has failed and may be nearing the end of its life. Please backup the data from the system if it’s booting up. Please enter your service tag # on the link below, select the OS, then download the BIOS from BIOS section onto the system and install it. Then run the diagnostics again.
