Problem with running HyperWorks 2017
Altair Forum User
Altair Forum User
I have a problem with Hyperworks Student Edition. After running the program loads for a moment and then the process dies. The second time it displays an error
'Folder  C:/Users/Michal/.Altair/AssemblyDb/udm20170/atCtrlSession_workspace already exists and not empty.' Then 'The library is closed.'
After deleting the folder the whole situation is repeated.
Any idea how to fix it?
Michal
  • Altair Forum User
    Altair Forum User
    edited March 2017
    I am having the same issue.
  • Altair Forum User
    Altair Forum User
    edited March 2017
    Anyone?
  • Rahul_P1
    Rahul_P1
    edited March 2017
    Close all the HW Apps > delete the .altair folder and other settings files (the files in the locations in the image below) > restart the app
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Didn't work. It's a problem with HyperMesh I suppose. I'm able to open HW app, HyperView, HyperGraph but not HM.
  • Rahul_P1
    Rahul_P1
    edited May 2017
    It is important to first try deleting the downloaded file and downloading it again from the site. To make sure the file is not damaged on download, run an md5 checksum on the downloaded file (just google md5 checksum) and make sure the checksum result matches the one given in the site where the files are downloaded from,
    1. Double click / run the Winmd5 checksum executable (download win md5 a freeware from the internet, please note we cannot be responsible for external content and info)
    1. Select the executable by clicking on the browse button or drag and drop the file into the window
    Regards
  • Altair Forum User
    Altair Forum User
    edited May 2017
    There is solution of this problem:
    Right click on HyperWorks shortcut and select 'Properties'. Next remove '/clientconfig hwfepre.dat' in Target line.
    Regards
  • Rahul_P1
    Rahul_P1
    edited May 2017
    Michal1509,
    Can you please confirm if the above has helped you?
  • Altair Forum User
    Altair Forum User
    edited June 2017
    I had the same problem, but just the lukasz's solution worked in my PC.
  • Altair Forum User
    Altair Forum User
    edited January 2018
    I have the same problem. While deleting the part that lukasz mentioned worked for being able to run HyperWorks, when I try to open HyperMesh in HyperWorks I get the exact same errors again. Deleting the above mentioned folders did not work. I already tried reinstalling the program and opening it as administrator. Both didn't work. Is there anything else I could try?
    Thanks a lot!
    Kind regards
    Antonia
  • Imoto
    Imoto
    edited April 2018
    Please try to remove the following folders.
    %USERPROFILE%\.Altair
    %USERPROFILE%\hweDefaultWS
    %USERPROFILE%\AltairLibraries
    Thanks,
    Imoto
  • Altair Forum User
    Altair Forum User
    edited April 2018
    Finally, how to solve this problem ?
    I deleted the folder mentioned by Rahul Ponginan but it doesn't still work.
    Thanks for your support
  • Altair Forum User
    Altair Forum User
    edited April 2018
    Regards
    Did you try this?
  • Altair Forum User
    Altair Forum User
    edited April 2018
    Thanks for your answer
    Yes I did it. Now I can open the software. But I can only read my models with the results. I can't create a new model...
  • Altair Forum User
    Altair Forum User
    edited May 2018
    SOLVED !!!!!
    The problem was my username containing diacritic sign ' ł '. I created a new guest account and application works fine. This same problem occurred during ANSYS running.
  • Altair Forum User
    Altair Forum User
    edited May 2018
    YES !
    Thank you michal1509 ! My USER name : Théo with an 'é' was the problem...
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited May 2018
    SOLVED !!!!!
    We are 2018 and Hyperworks software is still NOT in compliance with Unicode !
    Unbelievable !!!
  • Altair Forum User
    Altair Forum User
    edited June 2018
    When I click to open Hyperworks a windows appears with the following message:
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.ecc96f380fbf44b6fdbfd5204d19b449.png
    Does anyone knows where is the problem and how can I solve it? I pasted the license to the correct file.
    Thank you.
    Adrià
  • Rahul_P1
    Rahul_P1
    edited June 2018
    Use windows folder options > unhide known extensions, to make sure the file is named altair_lic.dat and not altair_lic.dat.dat,
    You need to confirm if the Ethernet address in the license file is the correct one and matches the one in your machine.
    When you open the license file in a text editor you will see an Ethernet address there in a line that says 'ETHERNET =
    The Ethernet ID is the ID of your machine which is exactly 12 hexadecimal numbers. For example D4WRF478F398
    Run ipconfig/all in command window and check for physical address under Ethernet adapter local area connection:
    The listed physical address under Ethernet adapter local area connection should be used to generate the license file, if there is no listing of Ethernet adapter local area connection, the address under Wireless Adapter LAN Wifi must be used.
    That means if the address provided as above does not match the one in the license file, please request for the license file again with the correct Ethernet ID.
    You can check your computer’s Ethernet address, by using the almutil -hostid application from the Start > Altair > Tools > Admin tools Menu and compare it with the result in the command window,
    Alternatively run getmac in command window to find out available Ethernet addresses to cross check as well,
  • Altair Forum User
    Altair Forum User
    edited September 2018
    SOLVED !!!!!
    Is there any other solution that does not imply creating a new guest account? In other words, is it possible to change the username? I tried but it didn't change in the directory C:/Users/Julio Armario Díaz so i'm still getting the same error.
    Thanks for helping
  • Rahul_P1
    Rahul_P1
    Your working directory can be any folder, please change it to a folder with a simple name and no symbols as described in the post above.
  • Altair Forum User
    Altair Forum User
    edited October 2018
    How I can change the location of '.Altair' folder that the software automatically create on my user folder . The name of my user folder is not valid for the software and I don't want to create another user for use only hypermesh.
    Regards
  • Pranav Hari
    Pranav Hari Altair Community Member
    edited October 2020
    Hi Luis M Pérez
    You cant change the location of the .'Altair' folder created on your user folder.
    Instead you can change the working directory
    Refer this forum post.
    https://community.altair.com/community?id=community_question&sys_id=c84688761b2bd0908017dc61ec4bcb68
  • Altair Forum User
    Altair Forum User
    edited July 2020
    go to search bar
    type '%temp%' and then enter
    delete all the temporary files
    and run the Hypermesh software
