I'm new in Optistruct and I want to make a static analysis of a composite part. I created a Laminate with PCOMPP property. I'm trying to assign the failure criteria Puck to my part. Is it necessary to create a MATF card for this and what should I enter in the card? Is it also necessary to select SOUT as YES on each Ply card for PCOMPP?
Thank you in advance for the help
