Free Size Optimization with interface laminates
Hello everyone,
I am currently working on an free size optimization of a wing consisting of a laminated top and bottom half.
Therefore i am pursuing a ply-based approach. When adding an interface laminate to my design variable the optimization terminates with the following error:
Is there any known solution for this issue? If not, what is the explanation behind it?
I have added my provisional model, if someone wants to take a look at it.
It contains some dummy material properties/load cases yet, but if some other major modeling mistake stand out to you, i would be glad if you share them with me.
Thank you in advice for your help!
Best regards,
Lukas
No comments on this post.
