FRF error 2094
Hi sir,
I am getting an error while solving FRF analysis, i.e.
*** ERROR # 2094 ***
EXCITEID on RLOAD2 # 9 data references follower force or nonexistent
DAREA/static loading with ID # 4.
There were 2 error messages during input processing.
The first message is repeated below:
==== End of solver screen output ====
==== Job completed ====
Please help me, as I am running out of time.
Regards
Rajendra Prasad
Borgwarner
Hi Prasad,
Could you please let us know the type of loading you are exciting the structure with
Thanks
Vikas
0 -
Thanks for reply vikas,
inputs are
Freq range: 50 to 500Hz.
Gravity: 2G
Damping: 2% & 4%( 2 simulations)
Loads I applied are
At the place of constraint, SPCD loads are also applied in all 3 dimention( towards specified dirc, 9810 N/mm2, load is applied).
Tabled1 is applied, range of freq 50 to 500Hz & gravity 2G is applied
Tabdamp is applied for damping i.e 2%
RLoad2 applied to merge SPCD load and Tabled.
Load step
Rajendra
0 -
Hi Rajendra,
Apologies for the delayed response
Could you please set the TYPE to ACCE on the RLOAD2 card and re-run the job
Thanks
Vikas
0 -
Altair Forum User said:
Hi Rajendra,
Thanks
Vikas
Still error is showing
0 -
Maybe if you share your fem-file someone can help you.
0 -
Hi Rajendra,
Thanks
Vikas
Hello friends,I hace the same problem, can you help me, please?
