Hi All,
Any of you did face this issue before?
Initialize the model got no error, then while running , it stop in ERROR TERMINATION with the below message.
MESSAGE ID : 110
** ERROR : RIGID BODY ID=121767 UNSTABLE
ERROR TERMINATION
Normally what kind of situation will cause this error? my RB created when I use bolt connection. so i suppose it should not be the RB problem but should be other problem.
Thanks.
Kin Poh
