Hi experts,
Could you tell me how to do the counter function in PSIM?I want to count the number of pulses. but I don't have any function block I can use.
You can find the generate "Up/Down Counter" in "Element >> Control >> Logic Elements >> Up/Down Counter".
You can always search for an element by using "Help >> Index" and type in the keyword.
If you can't find the block, you may use other PSIM blocks to build your function.
For example, to build a counter, you may use one of the Flip-Flops and a few logic gates.
