Does PSIM 10 supports generating c code specifically for Myway PE-Expert 4 platform. If yes, Could I have an example file? I have a code in PSIM that generates PWM outputs for an inverter, and I need to generate these PWM outputs in real using Myway PE-Expert 4 DSP platform. I want to generate the C code for Myway using the PWM code I developed in PSIM. Thanks for your help!
