I created a schematic using simcoder block where I used a square wave block. I kept 720Hz and 50% duty cycle for the block. The thing is in simulation results the block output does not show a pure square wave.Can you explain why? I uploaded the schematic and simulation results here.
Thank you
Here the simulation result is for HF1 shown in schematic
Hi @farhanaislam92,
I will look into this and get back to you.
Regards,Amit
Thanks, Amit. I am looking forward to listening from you.
Regards,Farhana
