This is a simple circuit but how does one get the correct impedance data at the xfmr input? Setup is just a 12.5ohm load, an ideal xfmr with N=2:1, and a sin source. The impedance should be 50ohms but what I get from the simulator is Vin and Iin. I want to determine V/I but how? Tried FFT but it looks good for V signal only but how to do that to the current? What I want to do is be able to take the FFT and V and I, get mag/phase for both and then I can determine Z by using V/I.
