I'm currently using PSIM and I went through all of the code generation tutorials. I'm designing a nonlinear controller for a three phase inverter. The switching frequency of the circuit is 10kHz however when I digitized the circuit by adding the delay I had to use a sampling frequency of 100khz. In the PSIM tutorials the switching frequency is also used as the sampling frequency. I haven't flashed the dsp with the auto generated code as yet but do you think this would be an issue.
Thanks,
Nadia
