In f28335, INTR time block can be used to generate a desired frequency square wave at dio pin. Is there a way to generate a few internal square at desired frequency?
How to make a code generation compitible monostable in Psim?
The square wave voltage source is code gen compatible, the resolution of the duty cycle will be a ratio of the interrupt frequency and the square wave frequency.
To make a code gen monostable you can use a c block and define one yourself.
