I've watched the tutorial on "Inverter design with average current and voltage loop control" I'm trying to perform an ac sweep of a three phase inverter. I'm using the SPWM method.
I'm not getting smooth curves for my phase and amplitude curves so I wanted to confirm if my ac sweep is correct. I am using the sinusoidal perturbation with a summer and sine wave inputs. The original simulation works fine. The dc input is 30Vdc with an output voltage of 15Vpk. I've set the amplitude of the perturbation as 15Vpk and set the source amplitude of the perturbation in the multisine block as 10%. So I'm not why I'm getting erroneous results.
Thanks,
Nadia
